Slow day on the Board, so here's a few questions.
Are these elements or filters cleanable ? ie. can you blow or brush off any silty deposits ? Or can you back-flush them ? Are they still available from the General ?
Thumbnail shows the two kinds of fittings I have on my carbs; one with steel gasket (to bowl) and the other a kind of fiberboard. I assume the order of assembly is as shown on the top row ( fitting, gasket, filter gasket [very thin, like paper], filter itself [point facing incoming gasoline], and finally the spring, against the small center hole in the filter).
