C-1 Speedometer - NCRS Discussion Boards
C-1 Speedometer
  • Richard P.
    • May 31, 2002
    • 190
    C-1 Speedometer
    I drove my '61 on the road for the first time in 7 years last week! The speedometer was making noise and waving between 20mph and 80mph while the car was going at a steady speed. Will oiling the cable or the speedometer fix this or is something else required? Thanks in advance.
    • May 31, 1974
    • 8400
    Re: C-1 Speedometer
    before removing the speedometer, i'd remove the speedometer cable from its housing, clean and spaingly lubricate the cable. and re-install. don't overdo the lubricant. i use an old AC speedometer lubricant similar to brake shoe white lube.mike
    • Bob H.
      • July 31, 2000
      • 821
      Re: C-1 Speedometer
      Hi Richard:
      I agree on removing the speedometer cable which is pretty simple. I would clean it well. I have used a spray graphite on mine with good success as I had the same problem. I think it was called loc-ease. Whatever you use you don't want a lot of extra on the cable as the fluid could run up and into the speedometer which may cause you unnecessary grief. Good luck.
      Bob
      • Stephen R.
        • May 20, 2008
        • 302
        Re: C-1 Speedometer
        I read somewhere that you should remove the cable and sparingly lube only 2/3's of the cable, leaving the 1/3 nearest the gauge without lubricant. As you drive, the cable will draw up the lube to cover all of it. Too much and the lube is in the gauge, gumming up everything. I believe this procedure applies to the tach and speedo. Also Corvette Centeral sells a cable lube.
        • Richard P.
          • May 31, 2002
          • 190
          Re: C-1 Speedometer
          Thanks guys,
          I'll lube it up tomorrow night and try it again.
          • Valeria H.
            • July 27, 2009
            • 463
            Re: C-1 Speedometer
            Please let us know the results.
            Valeria
            Valeria Hutchinson
            Past Chairman of the Carolinas Chapter
            1960 Roman Red w/ White Coves -"Bella"
            2005 Millennium Yellow 6 speed 400 HP - "Trixie"
