1963 Rear differential leak - NCRS Discussion Boards
  • Arthur S.
    Infrequent User
    • 7
    I have a 63 SWC, and have replaced the differential yoke seal three times and it continues to leak. It seams to leak right after driving the car. The fluid level is correct and it only leaks at the driveshaft yoke. Does anyone have a suggestion, as to the cause.
  • Timothy B.
    • April 30, 1983
    • 5196
    Re: 1963 Rear differential leak
    Arthur,
    If the yoke has a groove where the seal rides you can purchase a seal with the sleeve for the yoke collar.
    I bet your leak is coming from the splined shaft on the yoke and pinion gear. This area has to be sealed when installing a new seal or the assembly will leak for sure. Don't ask me how I know...
    • Gary R.
      • April 1, 1989
      • 1799
      Pinion seal leaks are usually from:
      • No #2 Permatex on the pinion splines
      • Groove in the pinion yoke OD, as mentioned speedy sleeves avail- I use them all the time
      • cheap seal. I found seals in kits or from parts stores are cheap and fail. I use only CR/SKF (USA) or National(mexico made now)
      • I have a box full of new seals from kits that I had used for years but after one failure I just box them up. If you want to try one you can have one. I would use the CR though.
      • Arthur S.
        Infrequent User
        • 7
        Timmothy and Gary, thanks very much for your guidance, I was going nuts, not to mention all that work taking the seals out. My frustration level was getting very high.
        Art
        • Gary R.
          • April 1, 1989
          • 1799
          Did you fix it?
