61 aluminum 2x4 intake manifold. - NCRS Discussion Boards
  • David S.
    • February 23, 2009
    • 46
    Hello,
    My books are conflicting on torque specs for the 2x4 aluminum intake manifold, which shows 20-25 lbs. Seems kind of too much for an aluminum manifold to me, is the sequence to tighten the bolts the same as the cast iron one? Any information appreciated...thanks.
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 61 aluminum 2x4 intake manifold.
    David
    20-25 is correct and no difference in procedure then cast iron manifold.
    • David S.
      • February 23, 2009
      • 46
      Thanks for the information Terry, better to ask before breaKing the piece.
      • Stuart F.
        • August 31, 1996
        • 4676
        I have broken off an end flange on one back in the day. Many of the bolts were hard to get at with the torque wrench and sockets we had then, so we got used to using just box end wrenches and tightening to the first grunt. Not a good idea.
        Stu Fox
        • Dale S.
          • November 12, 2007
          • 1224
          With Alum. better too little than too much. D/
