ran some numbers on my 58 today rear end etc. what gear does it have or had? - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    serial number: J58S108524
    motor: CEa194062229xtc...B8234
    back of bell housing: 3959532
    here is the part I would like to find out is what my rear end codes mean I did a search on here with the prefix didn't get anything.
    rear end: CF188 & 125899
  • Bill M.
    • April 1, 1977
    • 1386
    Re: ran some numbers on my 58 today rear end etc. what gear does it have or had?
    Brandon:
    The original codes for a '58 rear would be AE,AH,AN,AP,AQ,AS,AT,AU.
    CF is used on the '62 4.56 posi, but the date code doesn't work (according to the NCRS Specifications Guide).
    Bill
    • Terry D.
      • May 31, 1987
      • 2691
      Brandon
      Are those all the numbers on the rear end? Are you sure you typed them in correctly? Where is that CF number located?
      Can you post a picture?
      • Brandon T.
        • October 23, 2008
        • 872
        My dad wrote them down he's 55 so I assume that was with a flash light and his "cheaters"..
        so it might not be all of them or he wrote them down wrong etc. When I get off these 6 12's nights I'll take a look myself.
        • Mike E.
          • February 28, 1975
          • 5138
          Probably is 3725899---that's a non-posi housing from early 60's vintage. (posibly late 50's also)
          If casting date is as typed, that's either 58 or 68. If 68, an over the counter unit.
