Glass Bead blaster grit size - NCRS Discussion Boards
  • Steve L.
    • June 30, 2001
    • 763
    What bead size is everyone using?
    I'm just setting up a small cabinet. The local suppleir has BT7 which converts to:60 to 80 mesh; Bead size .007 to .010"
    There is also a bag of walnut shells. Is there any use for this?
    Steve L
    73 coupe since new
    Capital Corvette Club
    Ottawa, Canada
  • Jim D.
    • 2884
    Re: Glass Bead blaster grit size
    I use 80 grit glass beads.
    • Harmon C.
      • August 31, 1994
      • 3228
      I use walnut shells for alternator cases or any other light work and at low pressure they remove stains and clean up brass contacts.
      Lyle
