1954 shift lever removal - NCRS Discussion Boards
  • Jerry H.
    • April 22, 2007
    • 8
    What is the correct way to remove a 54 shift lever. With the cover off, the nut, that is holding the shift lever on, will not back off. It is turning with the threaded linkage.
  • Mike M.
    • May 31, 1974
    • 8408
    Re: 1954 shift lever removal
    try pulling the top of the lever towards the drivers door as you try to unthread the nut. mike
    • Brett H.
      • January 1, 1996
      • 367
      Once you have the nut removed, it should pull right off, like Mike stated. Sometimes, the entire nut and stud come out together. Make sure you don't lose the spring if this happens.
      • Jerry H.
        • April 22, 2007
        • 8
        Thanks guys. I just removed the nut with the stud. I was afraid that might cause a problem. I don't think it will be a problem replacing it that way. I am rechroming the shift lever.
