C1 (58) Trunk floor cover & fiberglass - NCRS Discussion Boards
  • Alfonso C.
    • November 1, 2001
    • 20
    The trunk floor cover plates are supposed to be metal for an early '58. How early is early? Mine is a Jan 23rd 1958 and came with 2 non original wired sized plates. Any clues?
    Also, adjacent to the rear bumper bracket area in the trunk. There are small aprox 3" by 3" bowl shaped protuberance (placed to prevent the rear of the leaf springs hitting the trunk fiberglass). Mine was previously repaired and one looks squared the other rounded. Can someone share some pictures from different angles so I can have the fiberglass repaired properly? Are those bowl shaped protuberance reproduced?
    Alfonso.
  • Doug F.
    • November 1, 1983
    • 322
    Re: C1 (58) Trunk floor cover & fiberglass
    January is plenty late for the fiberglass covers in my opinion, not sure if anyone repo's the small part you are referring to, here are a few pics of an old 58 body i have
    • Justin B.
      • March 1, 1996
      • 478
      My 58 is VIN 1327...Nov. 27, 1957 and the fiberglass plates have NEVER been off of the car. Are you sure that metal wasn't used on later production 58's?
      • Doug F.
        • November 1, 1983
        • 322
        The only 2 cars i can recall seeing the metal covers on were Mal Wieners #3 car and a black primered car that runs around Phoenix with a # 300 ish vin.
        • Dan H.
          • July 31, 1977
          • 1369
          I worked on 58 003 and it had the metal plates, held down with 1/4 20 clutch head screws. My 58 was #297, had clutch head sheet metal type screws that held the metal plates down, a real time saver for the production line workers I suppose, Mal's 003 was a prototype 58 on a 57 chassis, part number and all! Not sure when they went totally to the fiberglass covers, but they follow the metal ones.
          Dan
          1964 Red FI Coupe, DUNTOV '09
          • David L.
            • December 1, 1981
            • 116
            My '58, 2838, Jan 10, 1958 build date, has fiberglass plates.
            David
            • John N.
              • February 1, 1975
              • 451
              Our 58 #1004 RPO 684 car has metal plates.
              Regards
              • Alfonso C.
                • November 1, 2001
                • 20
                So, fiberglass cover will be. Thanks.
                Regarding the "bowl shaped protuberance", I'll appreciate more pictures for reference as C1 vette resources in my hometown (and country) are non existent.
