Harmonic Dampener Rebuild - NCRS Discussion Boards
  • Mike R.
    • August 30, 2009
    • 321
    The dampener on my 65 FI vette has rubber bulging around part of the circumference and the timing mark appears to have moved 2-3deg (I have not removed the dampener yet, just looked with mirror) The dampener is the correct "finned" style. A google search found a few re builders who use silicone rubber for about $95. Is silicone rubber the preferred solution? Any preferred vendors?
    Mike
    • 43296
    Re: Harmonic Dampener Rebuild
    Mike
    Mike----
    I don't know what's used for the elastomer component on these rebuilt balancers. However, the source that seems to be highly recommended by many is the Damper Doc. I believe they are located in Redding, CA. So, whatever they use seems to work well.
    • Scott S.
      • September 11, 2009
      • 1961
      Mike
      Hi Mike,
      My harmonic balancer needs a rebuild too. My research here and on the CF turned up "Damper Doctor" (http://www.damperdoctor.com/). A local engine builder also recommended "Damper Doctor", he sends 2 or 3 harmonic balancers from classic cars to them for a rebuild every year.
      Hope that helps,
      Scott
      • Scott S.
        • 1961
        Mike----
        You beat me to it, Joe.
