In shopping for a big block '66-'67 I found one that obviously has a restamped pad, I think.  I am not familiar with BBs, but on the '66 327s I have seen the VIN is just a 6 followed by the last six digits of the VIN.  This '66 427 390HP block has a 6, then the S, and then the last six digits of the VIN.  That can't be original, can it?
					Engine Pad Restamp
	Tags: None
Re: Engine Pad Restamp
I believe regular passenger cars had the plant indicator on the pad, but Corvettes did not in 66.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Steve:
I have seen two C2 cars with an S in the VIN stamp number.........both were restamps. Owner's name was Bubba Smith.
Michael:
There is no S in the VIN stamp derivative for 1966 for a factory original Corvette. VIN stamp should be seven digits beginning with a 6, followed by a 1 and then the last five digits of the VIN. (ie. 61xxxxx)
Larry- Top
Interesting, if the pad stamp is valid, then the VIN may have been changed to match it (from a non-Corvette 427 390 HP car), and if the VIN is valid somebody without much knowledge of Corvette engine pads restamped it in a way that was obviously wrong. Either way it makes one very cautious in buying a Vette without some very detailed examinations and research. I guess it is buyer beware big time.Big Tanks In the High Mountains of New Mexico- Top
Sure, it is listed as "numbers matching".Attached FilesBig Tanks In the High Mountains of New Mexico- Top
I'd say numbers matching but not original.
Look at the assembly date stamp. MAN is that thing perfect....Chris Enstrom
2011 Z06, red/red- Top
Guys do not be surprised if you find out some early 66 VIN derivatives on blocks were stamped with a different holder say from maybe the transmission!!!!
  Do not be surprised if that is not the case either I often have a vivid imagination.
For those of us still needing further education............ do we believe this stamp could be correct with its early VIN ??Tom Hendricks
I dn't have the info handy right now, but I believe I remember a discussion regarding the assy plant being instructed by engineering to add the "s" to either the engine or Trans stamps for the start of a model, causing some major aggrivation at St louis. I little jumping up and down hollering session caused the requirement to be recinded, but I don't have the details available at this time. I'd probably take a hard look at the pad machining, and if "old broached" likely buy it on an early '66, just my opinion.Bill Clupper #618- Top
