54 vette panel lights and courtesy - NCRS Discussion Boards
  • Ed P.
    • July 31, 2002
    • 270
    The instrument lights do not work and I had courtesy lights for a while and now the dont work. The power source is at the headlight switch correct with no fuse protection. I found wiring help for a 57 switch is it the same. Ed
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 vette panel lights and courtesy
    Clean it at the rheostat that's where you get the dash lights to dim and door lights
    • Cathy S.
      • August 31, 2003
      • 293
      A 54 wiring diagram identifies the dash hookup and how the headlight switch is connected.
      • Ed P.
        • July 31, 2002
        • 270
        Thanks for the info. Headlight switch is toast. Ed
        • Troy P.
          • February 1, 1989
          • 1284
          I've got several good used ones and one NOS if you are in need.
