Wheel backspacing dim - NCRS Discussion Boards
+ More Options
Posts
  • Jeff S.
    • July 31, 1984
    • 384
    What is the minimum backspacing dimension required to clear disk brake calipers? Is there any difference front or rear? Thanks in advance.
    Jeff
    Re: Wheel backspacing dim
    Jeff
    Jeff -
    Backspacing isn't the only issue for caliper clearance - it's a combination of offset, rim cross-section, and spider cross-section. All three have to be configured so the installed wheel clears the calipers.
