'75 Power Window Regulator Spring - NCRS Discussion Boards
  • Tommy F.
    • August 13, 2007
    • 97
    Can the window regulator spring be changed without removing the regulator from the door? It looks like it can be done, but with fresh paint on the car, I'm hesitant to pull the glass.
    After verifying wiring and contacts, changing a window motor, and cleaning / lubricating window tracks, I finally figured out that the spring on the drivers side of my 75 is INSTALLED BACKWARDS ! This finally explains why the window strains to go up, and practically "falls" down when the switch is operated.
    Since I'm almost done (Ha!) with the project, I'll let y'all know when I find somthing that "Bubba" didn't fix before I got the car.
    Thanks for the help,
