I was wondering if some of you with 1964 Vettes with back up lights would please post and/or send me some photos of how the back-up light wire is routed through and up from the lower clip that holds the speedometer cable. I also need to see where the clip is located down by the underbody tunnel so the speedo cable doesn't interfere with the clutch fork when it moves (the original clip and hole are gone).
Also, and more importantly, please post some photos of how your two backup light wires are routed after they run up through the clip that is located on the firewall and where the two connectors meet. Do the connectors just hang in mid-air? Do they sit on the 'little shelf' next to the wiper motor? Is one of the white plastic 'zip tie' wire straps (that hold the hood release cable, squirter hoses and wire harness) holding the connectors up? What keeps the wires taught against the firewall so they don't interfere with the clutch fork? The clip that is about 1/2 way up the firewall doesn't keep them tight and therefore, won't prevent them from interfering with the clutch fork etc?
My AIM shows the connector that comes through the firewall being held up by one of the white plastic wire 'zip ties' and then the lower connector plugs into it. However, my back-up light switch wires coming from the tranny are not quite long enough to do that. Should they be? My back-up light switch is a repro with a green wire and a pink wire mated together.
I have searched all of my books and photos and can't find a good shot of what I need to see. Any help would be greatly appreciated.
Thanks, Tim
Thanks, Tim
