Poor Man's Air Conditioning - NCRS Discussion Boards
  • Roger P.
    • February 25, 2009
    • 354
    Greetings:
    I hope you all enjoyed cruising your Vettes during this past summer. For many of you, it's getting real close to hibernation time . However, I live in South Florida and am getting ready for the best cruising weather of the year ! However, our summers are brutally hot & humid which can make driving very uncomfortable - even in a convertible. Without A/C, what can be done to get some air movement? As I am somewhat of a "McGyver" kind of guy, so I decided to install fans with stock-looking chrome A/C vents in the same location as the factory A/C vents to improve air movement for both the driver and passenger. I also purchased seat coolers for both seats which moves a thin layer of air via a fan across your fanny & back. With the help of my brother (who owns an automotive & marine shop), we removed the in-line fan controls, wired the slim "Torpedo" fans to the car's factory 3-speed defroster/heater fan switch (we previously installed an in-line heater hose shut-off valve), and tie-wrapped the wires under the dash. We kept the in-line fan control for each seat cooler which is located low in front of the seat, and tucked the wires between the carpet & center console trim on each side. He wired the coolers somewhere near the back of the radio so they are energized as soon as the key is turned on (they can be turned off with the fan switch, too). I had to do some custom fabrication to get the A/C vents to fit on the fan grille, but it wasn't difficult once I worked out the details. It's not air conditioning, but both the fans and the seat coolers really help make the ride much more comfortable - and everything cost me less than $ 250.00! With the cowl vents open and the heater knob pulled out to the first detent (with the heater hose valve closed), outside air is wisked through the fans to help cool the driver & passenger. Take a look at the attached photos and tell me what you think. If you're interested, I can give you more information on the fans, seat coolers, and A/C vents, as well as details of my A/C vent installation. By the way, it looks even better in person than in the photos . So far, it has been all positive reviews for those that have seen it and experienced the improved ride. The best part is that your pants and shirt stay dry and don't "sweat glue" to the seats - sweeeeet!!
    Cruisin' in comfort,
    Roger (50141)
  • John F.
    • March 23, 2008
    • 2408
    Re: Poor Man's Air Conditioning
    Yankee ingenuity. You got to love it!
    John
    • Roger P.
      • February 25, 2009
      • 354
      John, thanks for your kind words. I realize that my "cool" concept will most likely not appeal to the purists. However, I know there are many enthusiasts like me who want to keep our Vettes as original as possible, but still want some modern comforts and conveniences (I also installed 3-point seat belts for added driving safety). My "poor man's air conditioning" installation doesn't require any drilling or cutting, so the car can be returned to its original state very easily. From reading other posts, I know there are drivers out there looking to get some relief from the heat (that's where I got the idea of the heater hose valve). Your honest opinions are appreciated as I am interested in some feedback.
      Thank you,
      Roger (50141)
      • Cathy S.
        • August 31, 2003
        • 293
        My 66 vert also is garaged too much in the So Cal summers due to heat. I think you did a great job. And if it allows you to drive your vette more often is that not what its all about?
        Greg
        • Roger P.
          • February 25, 2009
          • 354
          Greg:
          Thank you for your reply. As I mentioned before, the fans really do look even better in person than in the photos. The installation gives the impression of Vintage Air and looks nearly original. Again, it's not A/C, but you do get a decent breeze from the fans, and the seat coolers keep your back dry. I am surprised that after more than 230 views, I only received 2 replies. I really am interested in what others think - both good and bad. If anyone is out there with an opinion, please share it. I have thick skin, so don't be worried about hurting my feelings (or boosting my ego ). I just want to know what other Vette owners think about my installation as I thought it was something that others living in hot climates (or summers in cooler climates) would be interested in for their non-A/C Vettes. Any thoughts??
          Thank you,
          Roger (50141)
          • Ron R.
            Infrequent User
            • January 31, 2007
            • 18
            Roger I would be interested in learning where to acquire the seat coolers as I too live in Florida.
            • Bob H.
              • July 31, 2000
              • 807
              Roger:
              I improvised on my daily driver when the factory air quit!!
              • Roger P.
                • February 25, 2009
                • 354
                Ron:
                I purchased my seat coolers from an online vendor called Always Brilliant.com (http://alwaysbrilliant.com/). The seat coolers are available from other online vendors as well, so Google "car seat coolers" and check for the best price (should be in the $ 55- to $ 65- range). They are manufactured by a company called WWT Group, and I believe they can also be purchased from them directly. If my memory serves me well, they come in three different colors; black, black & silver, and tan (mine are all black to match my interior). A couple other companies make similar seat coolers, but from my research, these were rated the best. They have an adjustable fan control switch, but you will most likely run them at the highest speed all the time as they don't blow the air very hard. I think this is done on purpose so you don't have an annoying feeling on your back & behind while driving. However, they do work by keeping you cool and dry. For drivers in cooler climates, another company makes a seat cooler/heater combo, but we certainly don't need that living in Florida!
                Bob:
                Thanks for the great A/C idea! You did a great job on your car/mobile home. Now I'll have to trade my Vette for a tanker to have the additional fuel needed for the generator, but I'm sure it's worth it .
                Best regards,
                Roger (50141)
                • John F.
                  • March 23, 2008
                  • 2408
                  Roger, where is a picture of the seat cooler? I couldn't find it on that site.
                  John
                  • Ron R.
                    Infrequent User
                    • January 31, 2007
                    • 18
                    Originally posted by Roger Piper (50141)
                    Ron:
                    Bob:
                    Best regards,
                    Roger (50141)
                    Thanks Roger for the info.
                    • Roger P.
                      • February 25, 2009
                      • 354
                      John and Ron:
                      It looks like AlwaysBrilliant.com stopped carrying the seat coolers . However, I found the best deal for the same seat coolers at Smarthome via Amazon. Click on the following link and you will be directed to the promised land of comfort: http://www.amazon.com/12V-Cooling-Ca...140609&sr=8-12. They are being offered at a good deal; $ 55.97 each with free shipping . I cruised around today with a friend for a couple of hours and we both enjoyed a comfortable ride with the top down! By the way, they come with two adjustable "click & lock" straps plus an elastic headrest strap. If you don't have headrests like me, just weave the higher "click & lock" strap through the elastic behind the seatback and the seat cooler will stay nicely in place. I attached two photos to give you a better view of the coolers installed. Let me know how they work for you
                      Good luck,
                      Roger (50141)
