1962 Sticking Coke - NCRS Discussion Boards
1962 Sticking Coke
  • Alan F.
    • May 31, 1996
    • 13
    1962 Sticking Coke
    I have a '62 300hp with a Carter AFB carburetor. The choke was sticking open upon cold start. I have cleaned (and polished) the piston in the choke assembly several times. The last time I applied a small amount of white Lithium grease. The whole mechanism is free and works properly except for one situation. After the car has been brought up to temperature and then cooled down again, the choke sticks open when depressing the accelerator. A slight nudge on the choke lever above the bimetallic strip frees it up and then it engages properly. Any suggestions on how to fix?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 1962 Sticking Coke
    loosen the screws holding the choke plate and try centering it the choke housing on the carb. i have seen some where a little file work on the plate was needed because the choke housing had been distorted for some reason
    • Harry S.
      • July 31, 2002
      • 5346
      Clem thanks, have the same problem on my 63 WCFB.
        • 15706
        Grease or oil on the choke piston is going to eventually cause problems. I suggest using a graphite product like Lok-Eze.
        Also, be sure the tiny O-ring between the choke housing and carb body seals properly and that the tube in the exhaust manifold is not corroded through, allowing exhaust gas into the choke clean air system.
        • Alan F.
          • May 31, 1996
          • 13
          Thanks for the comments. I also noticed there might have been some binding or warping on the lead disk behind the bi-metalic spring. I cleaned up and filed down some. Seems to be working so far
