engine label adhesive? - NCRS Discussion Boards
+ More Options
Posts
  • Peter M.
    • April 8, 2007
    • 570
    What adhesive cement or glue is best to use to afix the EPA, belt routing and other miscellaneous engine compartment labels? Mine are coming off and I want to re-glue them with something that will work well and not make a mess.
  • Peter M.
    • April 8, 2007
    • 570
    Re: engine label adhesive?
    Anyone know the answer to this mystery?
    • Dick W.
      • 10483
      Very thin coat of contact cement. You can dilute the cement with 3M adhesive remover. I would try a small area before you do the complete label.
      Dick Whittington
      • Glenn S.
        • October 21, 2008
        • 1
        Thank you, Dick.
