Calling Joe Lucia. Need part# - NCRS Discussion Boards
  • David M.
    • August 31, 1992
    • 33
    Hi Joe,
    I am looking for the part # for a oil pressure sending unit for a 90 ZR-1. I found part # 100961 but it is discontinued. Any help would be appreciated.
    Thanks, Dave
    • 43279
    Re: Calling Joe Lucia. Need part#
    Originally posted by David Mognoni (21600)
    Hi Joe,
    Thanks, Dave
    Dave-----
    First of all, there is no GM #100961. However, I think you've got the oil pressure and oil temperature senders mixed up. The oil TEMPERATURE GAUGE SENSOR for your application is GM #10096135. It's still available from GM for about 50 bucks, GM list.
    The OIL PRESSURE SENSOR is GM #12555492. It's also still available from GM for about 50 bucks, GM list.
    There's also an OIL PRESSURE SWITCH somehow involved, but I don't fully understand its application. It's GM #25036935 and it's also still available from GM for about 25 bucks, GM list.
    If you post a photo of the failed unit you have, I might be able to ID it.
    • Tom H.
      • December 1, 1993
      • 3440
      I believe the switch Joe mentioned is the low oil pressure sensor switch. Possibly a switch used to relay a low oil pressure condition to the DIC.
      I also seem to remember there was a feature of the ZR1 / LT5 that would not allow the engine to start until proper oil pressure was achieved. Can't confirm that though without a little research.
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • David M.
        • August 31, 1992
        • 33
        Thanks Joe, It was the oil pressure sender # I needed. It is ordered and on it's way.
