Dressed like an L79 - NCRS Discussion Boards
Dressed like an L79
  • Joe B.
    • January 1, 2003
    • 14
    Dressed like an L79
    I have a 67 327/300 car that came previously restored with the 350HP aluminum manifold. I like the look and would like to complete the "dress" by adding the correct water pump with the by pass hose into the manifold which currently has a plug. If I make this change do i have to change any pulleys, etc? I am not having the car judged. Thanks.
    Re: Dressed like an L79
    Joe -
    No, you won't have to change pulleys.
    • Tom D.
      • September 30, 1981
      • 2139
      Would you mind posting (or sending) a photo of the oil "breather" tube that runs up to the air cleaner from the driver's side rear of the engine block.
      Thanks (I am having trouble getting the paragon replacement for 300HP to fit correctly, and wonder if they sold me a 350 HP version instead.)
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        Tom -
        Here's my '67 300hp, with what I believe to be the original rear vent tube; the 350hp tube is angled up higher and is longer due to the high-rise intake manifold.
