1968 Cross Shaft Finish - NCRS Discussion Boards
  • William H.
    • January 1, 2006
    • 210
    Can someone help me determine how I should refinish my clutch cross shaft on a 1968. It appears that someone may have painted mine with some type of clear so I need to correct. Do you get them zinc plated? Thanks for any insight.
    Bill Hyndman
    The 'Sound of Freedom' if not a UH-60 Blackhawk, then it must be a Corvette!
    1962 Big Brake Fuelie
    1965 Fuelie Convertible
    1968 L89 Convertible
    • 43258
    Re: 1968 Cross Shaft Finish
    William-----
    I think that originals were galvanized or electro-galvanized. However, this finish is very close to zinc plating, so I don't think that most would be able to tell the difference one way or the other.
    The shafts were definitely not clear-coated.
    If you have the shaft zinc-plated, you MUST ensure that it is properly annealed subsequent to plating. Otherwise, I can almost assure you that the welds at the lever arms will break in due course.
    • Patrick N.
      • March 10, 2008
      • 954
      to add to joe's comments, they are also a dull finish- bright but not shinny or polished.
      Pat
      68 427 / 400
      88
      • Wayne M.
        • March 1, 1980
        • 6414
        William --- This is an NOS (service) cross shaft for a '65-66 big block only, but as the others have said, the finish / plating should be similar to this one, IMO.
        • William H.
          • January 1, 2006
          • 210
          thanks ver much Joe
          Bill Hyndman
