C1 bellhousing part number - NCRS Discussion Boards
  • Paul Y.
    • September 30, 1982
    • 570
    A friend of mine needs to know the casting number for his 60 vette bellhousing. I told him that one or more of you gurus would be able to tell me. Thanks in advance. Paul
    It's a good life!
  • Jerry C.
    • November 1, 1995
    • 741
    Re: C1 bellhousing part number
    60 only aluminum bellhousing#3764591
    • Paul Y.
      • 570
      Thanks for the quick reply Jerry. It's appreciated. Paul
      It's a good life!
      • Paul Y.
        • 570
        Beings that this is a somewhat hard to find part, is there another bellhousing that would work even though not correct? Thanks in advance. Paul
        It's a good life!
          • 43247
          Paul-----
          Yes. GM casting #3733365 (cast iron) or GM #3779553 (aluminum).
          • Stewart A.
            • April 16, 2008
            • 1035
            Early cars had the cast 365. Mine is 1270 and has the cast. Not sure what Vin number they actually changed to alloy. Stewy
            • Joe M.
              • February 1, 2005
              • 590
              Also cast # 257 for a cast iron bell with the narrow clutch fork window.....
                • 43247
                Joe----
                The '257' bellhousing was used for passenger cars only. Some of these may be drilled and tapped for a different clutch fork stud that will not be compatible with the Corvette clutch fork. I think that later ones are drilled and tapped for the same stud as Corvette, though. However, there may be other differences that would present a problem in a Corvette application.
                • Joe M.
                  • February 1, 2005
                  • 590
                  Joe,
                  I just pulled that 257 housing from my 57 that was retrofitted with a 4speed when I originally purchased it. Din't mean to imply it was a vette bell but one that would fit and had the small window.
                  Interesting to learn of the differences.
                  Joe
