The other day I re-installed my 1970 hardtop after having it off of the car and stored for a long time. I have removed/installed it only 2-3 times during the 10 years of my ownership, and each time I tell myself that there's gotta be a better way.
To install the hardtop, I have to first initially fasten the hardtop to the decklid by installing the bolts on each front side of the top/decklid, then pull the decklid release handle, gently raise the hardtop/decklid as one piece, have someone hold it up while I install and tighten the hardware in the three remaining holes at the back and rear sides, then gently lower the whole thing and lock the decklid in place. The reason I have to hold the hardtop/decklid up is that is the only way I can see to get to the underside of the three holes at the rear to tighten the nuts because the softop prevents me from doing so when the decklid is down. This seems awkward as holding the hardtop/decklid up is quite heavy and the only thing at that point holding the hardtop on is the two bolts on the side. Am I missing something here, or is that the only way to do it?
