1966 Glove box items - NCRS Discussion Boards
  • Ronald L.
    • October 18, 2009
    • 3248
    Question on the correct contents of the glove box.
    Owners manual
    protect-o-plate/ owners protection plan book
    AMFM guide - what is correct - I see different items listed such as this link: (eBay item number: 130214248566 0r 180392437365)
    Plastic bag
    anything else?
  • Joe R.
    • May 31, 2006
    • 1822
    Re: 1966 Glove box items
    Ronald,
    It sounds like you are working without the Judging Guide. I would suggest getting one from the NCRS store. The Judging Sheets are available on this web site.
    Joe
    • Ronald L.
      • October 18, 2009
      • 3248
      I have the worksheet, but that does not specify the contents.
      The 1966 guide is not available from this website - yet - all other years have the "Buy" button...
      And - the question on the AMFM - which one is correct?
      Small points (5) but if one is to get these items, might as well get the correct items.
        I don't have a '66 AIM handy, but the '67 book lists the ancillary items shipped with the cars (by PN) in a table at the front of the book, UPC 0, Sheet C1.
        • Ronald L.
          • October 18, 2009
          • 3248
          Thanks - that is where I was a few weeks back.
          The question is on the AMFM booklet - what did that look like as there are multiple vendors saying they have it and they are distinctly different, have not replied if & what the part number is on the booklet they have for sale.
          Two of those items are the item numbers I put in the original post.
            They all look pretty much the same with the differences being PN and revision/edition. The books changed over time as more and more FM stations across the country came into service.
            So, to purchase a 'correct' booklet to match your car, you need to know what PN was originally shipped with the car (either AIM or JG book) and then verify its revision/edition date, rationalizing it to your car's model year and actual build date...
            Those who offer a book for sale and simply state that it's 'correct' without giving you both the PN and revision/edition data, are pretty much whistling 'Dixie'...
            • Dave S.
              • August 31, 1992
              • 2926
              Owners manual
              Plastic bag
              anything else?
              Ronald,
              I do not have the 66 Judging Guide but 66's used a 7291985 radio sheet. I believe 66's also have a yellow radio tag on one of the radio knobs. Both are available in reproduction if you are inclined to go that route. Originals are scarce and can be expensive. 64's and 65's had an AM/FM Pocket Guide but I believe 66's did not have one. Others can confirm.
              You will also need a trim ring card. They too are available in reproduction.
              • Michael H.
                • January 29, 2008
                • 7477
                Ronald,
                I do not have the 66 Judging Guide but 66's used a 7291985 radio sheet. Originals are scarce and can be expensive. 64's and 65's had an AM/FM Pocket Guide but I believe 66's did not have one. Others can confirm.
                Dave..
                You have it right. The AM-FM "Pocket Guide" was not shipped with a new 66. That item was 64 and 65 only.
                The radio folder for 65 through 67 was part number 7291985, as you mentioned.
                • Jeff A.
                  • November 1, 2005
                  • 199
                  Ronald,
                  If you have a hardtop, you'll also need a hardtop wrench in a cloth bag; with knock-off wheels, a "Quick Take-Off Wheel Instruction Card" (part # 3866414). The paper documents should be in a Chevrolet plastic envelope (part # 3834959).
                  Good luck!
                  Jeff
                  • Harry S.
                    • July 31, 2002
                    • 5330
                    Also, if you have a hartop and the hardtop is on the car, the bolt, rubber washer and nut should also be in the bag. They plug the holes when the softtop is up and keeps the water out.
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      I think only the rubber washer would be in the IP compartment if the hardtop is installed during judging. The bolt and nut would be used to mount the top.
                      • Harry S.
                        • July 31, 2002
                        • 5330
                        Brain check, thanks Michael.
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          I knew you meant to say washers only.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            Interesting discussion and input is much appreciated.
                            The Assembly manual indicates these g box items:
                            3879857 own prot plan
                            3879852 owners guide
                            3834959 envelope
                            license frame (2) 3875313 atach unit 3875313
                            3832456 wrench (COT)
                            3866414 card quick take off wheel inst - doubt this car had these
                            shoulder harness card - not on this car
                            3691215 bag (COT)
                            7291985 sheet - radio instruction upc u68
                            3827499 washer upc c07
                            did any one look at those eBay items numbers in the original post?
                            just to see if one of those two are the AMFM card indicated?
                            If the asm manual indicated this why the comment they were not shipping that way?
                            The only change referenced was 4/22/66 adding the shoulder harness.
                            the yellow hang tag is shown on pg f434
                            Very interesting discussion on the convertible top.
                            Question on that - if a car did not come with the hard top, was the lift panel different? I.E. did not have holes or?
                            Another way to ask this would be sans any g/box conv top items, what would the indicators be that the car came with one?
                            • Michael H.
                              • January 29, 2008
                              • 7477
                              The ebay auction you show for the AM-FM "Operating Instructions" is for a passenger car. It states "and stereo adapter" on the front page. The Corvette sheet states only "Chevrolet Corvette AM-FM Radio.
                              Ebay number 130214248566
