Uniroyal Laredo serial number info needed - NCRS Discussion Boards
+ More Options
Posts
  • Jeffrey G.
    • June 30, 1986
    • 77
    Hi,
    Has there been data published or does anyone konw how to decipher the serial numbers to determine the manufacturing dates for non-DOT Uniroyal Laredo bais ply white wall tires?
    I have the following codes (serial numbers) 05UL03, 05OL03, 1666OK, all the tires look identical otherwise.
    Thank you!
  • Jeffrey G.
    • June 30, 1986
    • 77
    Re: Uniroyal Laredo serial number info needed
    Anybody have any info on this?
      Jeffrey -
      This has come up before, and apparently that info is available for Goodyear non-DOT tires, but not for the other brands.
      • Jeffrey G.
        • June 30, 1986
        • 77
        John,
        Thanks for replying. When a car is presented for judging with all non-DOT tires (probably a fairly rare event) do you know if it's up to the judges knowledge to make a determination about if the tires are dated corrrectly? I assumed they decode the serial numbers? I mean if all the tires are "correct" (bias, corrct size, whitewall width and the brand, in this case Uniroyal Laredos were offered on production Corvettes during the model year), is there anything else?
        Thank you, Jeff
