I ordered the jude padding for under the dash with thick rubber covering. It is pre cut for the heater box and has four hole for the bolts. I tried installing it today, 2 of the bolts will not go through all the way. Does that padding go between the firewall and heater core boxes?????
And the nuts are speed nuts with the tar like material under it???
Last question
427 L68 oil line, according to the judging manual it is all steel from block to bracket and from bracket to gauge. I can not find it anywhere for sale. Os the guage correct???
Last question
