Color of Original 67 9-Leaf Spring - Gray? - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    Is the entire 9-leaf spring painted gray on an original 67? Does that include the center bolt and nut that holds the spring together? Thanks.
    Kirk
    • November 30, 1997
    Re: Color of Original 67 9-Leaf Spring - Gray?
    Kirk -
    The spring leaves were coated before it was assembled.
    • Kirk M.
      • June 30, 2006
      • 1036
      Was it colored or just a "clear" coating? I don't know why I thought I read somewhere they were gray? Thanks.
      Kirk
        • January 31, 1988
        • 43191
        Kirk
        Kirk-----
        It was a GRAY coating, not a clearcoat, at all. You can still purchase the same Ionoklad coating from Quanta Products in pint cans.
        • Larry M.
          • December 31, 1991
          • 2686
          Spring leaves were painted/dipped a gray color. Correct gray paint available from Quanta and others.
          The spring liners were not painted and should be black plastic.
          The lower spring mounting plate should be semi-gloss black.
          Larry
          • Chris E.
            • November 2, 2006
            • 1322
            Kirk-----
            Yup, I did that. But I made the mistake of brushing the paint on. I took a 1 point deduct for that in judging recently.
            I guess you can make your own spray cans, perhaps with a product form Eastwood? Dunno. Oh well, I'm not taking the spring back out unless it breaks.
            Chris Enstrom
            2011 Z06, red/red
              • 15573
              Larry
              My understanding is they were coated only on the bottom. If that is true, dipping might be a little difficult. I was also told the coating was brushed on.
              • Michael H.
                • January 28, 2008
                • 7477
                The GM blueprint did not specify a method of applying the coating. (print below)
                I heard that the coating was applied with a roller but I don't know this for sure. Makes sense though. Also possible that it was sprayed?
                  • November 30, 1989
                  • 11607
                  Yes, we've both heard that from the same source, and I think at the same time.
                  Allegedly done so with a large "horse hair" brush.
                  Patrick
                  • Brian M.
                    • January 31, 1997
                    • 1836
                    I did mine with a foam brush.
                      • January 31, 1988
                      • 43191
                      Terry-----
                      I have an NOS GM #354130 seven leaf rear spring. The spring appears to have the coating applied with a brush. I expect that other springs were coated in the same manner.
                      I'd attach photos but the spring is stored in a location that requires a lot of effort to get at and my back aches at the thought of getting it out.
                      • Michael H.
                        • January 28, 2008
                        • 7477
                        Patrick
                        Franz Estereicher posted a few years ago and discussed the spring and it's mfg process. I believe he also included information on the coating and the method used to apply it. Should be in the archives.
                          • November 30, 1989
                          • 11607
                          We learned it from him firsthand.
                            • 15573
                            Terry-----
                            I had one also Joe, but in a moment of weekness I was coned into selling it. THAT is a mistake I will not repeat. I do remember it was coated only on the bottom of each leaf.
                            • Kirk M.
                              • June 30, 2006
                              • 1036
                              So, what is the vote?
                              1. I will purchase correct coating from Quanta
                              2. Do I brush or roll?
                              3. Do I cover both sides?
                              My spring has some residual coating left on it where the bands were covered by one another. I will take some pics and post.
                              Kirk
