72 gas cap question- Joe L. - NCRS Discussion Boards
    • 6945
    Joe, I pick up a gas cap for my 72 coupe, what does the correct plating look like? this one appears to be a dull silver finish, has the smooth other ring and smc logo cork gasket as the jm says , What do you think? thanks Ed.
    • 43234
    Re: 72 gas cap question- Joe L.
    Ed-----
    Assuming that it has the correct embossed lettering, it sounds about right except for one thing: I don't ever recall seeing one of these with a cork gasket. All that I have seen have a black rubber gasket. I don't recall seeing it described as cork in the JG, either.
      • 15605
      I think 1972 gas caps are supposed to be gold dichromate, but I will have to defir to those who judge exterior more than I do. And yes, I know the TIM&JG does not say that.
        • 43234
        Terry-----
        Examples of the GM #3994339, the L71-74 gas cap that I've seen have definitely all had the "gold" dichromate finish. However, I'm less sure that very early examples of the 3994339 had this finish. If someone comes up with an apparently original 3994339 that doesn't have or appear to ever have had a dichromate finish, then I would say early examples of the 3994339 probably didn't have said finish. Certainly, later examples of the cap, still available to this day, have the dihromate finish.
        I don't think this cap was ever available in the aftermarket. If, by chance, it was, I would expect that the same Stant-manufactured cap was what was available.
          • 15605
          And I may be mixing up SERVICE and ORIGINAL parts -- this is not an area I usually judge. I know Reba knows the answer because I remember talking with her about her 1972.
          • Bill C.
            • July 15, 2007
            • 904
            My original cap was dull cad with a black rubber gasket in the ring.
            I had it replated accordingly for the restoration.
            Car is a April 72 assembled.
            • D S.
              • March 1, 2005
              • 1551
              Ed-----
              Joe, the 1970-1972 JG states black rubber gasket.
                • 6945
                I will look at gasket it appeared to be cork but may indeed be rubber, I thought the same as Terry with the gold diachromate , but it has the original plating- dull silver, smooth outter ring and smc marking. I think it maybe possiable replacements were the diachromate.I did look again at gasket, it is rubber.
                • Dick W.
                  • 10483
                  Terry-----
                  Joe I saw a NOS cap in a Stant box this weekend, cadium dichromate
                  Dick Whittington
                  • Kurt G.
                    • April 30, 2005
                    • 343
                    My original September 13, 1971 assembly '72 has the original gas cap, cad plated (dull silver) with a black rubber gasket.
                    Kurt Geis
                    Chairman, Midway USA Chapter
                    Targa Blue 1972, Top Flight and Duntov Award, 2014
                    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                    Arctic White 2013 60th Anniv Special Edition Conv.
                    • Mike G.
                      • July 31, 2002
                      • 709
                      the original was dull cad with black rubber gasket. the replacements, that you can still get today, are gold dichromate. i have a nos cap that is dull silver cad. the old original cap on my 72 is also dull silver cad. the same goes for the cap on my 70.
                        The current JG books say '71-72 caps are straight dull cad with black rubber gasket (early '71 have 'Caution Open Slowly add-on label while late '71 and all '72 had this warning embossed) and '73 is the first call out for caps with a dichromate wash, gold finish...
