Best place to get headlight motors rebuilt? - NCRS Discussion Boards
    • May 25, 2009
    • 37
    I need to rebuild my headlight motors. Where is the best place to send them?
  • Philip C.
    • December 1, 1984
    • 1117
    Re: Best place to get headlight motors rebuilt?
    Hi Terry, I have had great results from Steve Hack, great turn around and very fair shipping. Call him at 513-553-2080 hes in Ohio
    • Jimmy G.
      • November 1, 1979
      • 977
      Ditto Ditto
      • Donald T.
        • September 30, 2002
        • 1319
        You may want to try it yourself. The headlight motors are very easy to rebuild. The main drive gear is the typical item that gets worn out. You can turn it 180 degrees so it operates on fresh teeth, or just replace if necessary. Clean and apply fresh grease, and you should be good to go. The process has been outlined in the Restorer.
        • Wayne P.
          • January 23, 2008
          • 444
          Terry :
          Just an idea if you are handy you might want to do it yourself . Lots of good posts . I took them apart and back together with good results.
          • David P.
            • May 26, 2009
            • 16
            Corvette Specialities of Maryland www.corvettespecialtiesofmd.com
            Did a great job on mine.
            • Peter J.
              • September 30, 1994
              • 586
              Steve Hack must be good for Jimmy Gregg to recommend him - Because Jimmy taught me how to rebuild mine. And I have passed the favor on to a couple of friends. It is pretty easy and Don is right about turning the gear 180 degrees is the usual fix
              Pete
                • May 25, 2009
                • 37
                Thanks for the great information guys.
