'66 Seatbelt Removal - NCRS Discussion Boards
  • Jerry K.
    • September 21, 2009
    • 74
    To remove and replace my seat belts do I have to do anything underneath the car or just remove the nut behind the seats? Not the nut in front of the seat 'cause that would be me. I tried archives w/o luck. Thanks.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: '66 Seatbelt Removal
    Jerry, If I remember right, the 66 belts should come right out by removing hardware behind the seats. I don't believe anything under the car is required. As long as the captured "welded" nut on the outboard ones don't break loose, it's an easy job. Don't ask how I know about the nuts breaking loose !
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Mike Z.
      • 226
      Jerry-
      Both sides of the belt are held in place with shoulder bolts, not nuts-there are capture nuts riveted to the body. Normally, there is no issues getting them out with a proper socket/wrench from the interior-there is no need to go under the car to remove the seat belts.
      Mike Zamora
      #12455
        Originally posted by Mike Zamora (12455)
        Jerry-
        The inboard belts on a '66 are secured with nuts (on a stud that's part of the underbody reinforcement); the outboard belts use bolts.
        • Francis F.
          • April 1, 1978
          • 420
          Jerry to remove the belts you may want to go under the car
          and apply a spray to the bolt threads of item #1 shown in the
          drawing.This can be just barely seen when looking up in the area
          between the frame and the car body,a long extension on a
          material like kroil (spray can) will allow you to soak the threads
          before you attempt to turn the allen head bolt.Good luck
          Francis
          • Mike Z.
            • 226
            Jerry-you are absolutely correct, it has been a couple of years since the last mid-year I pulled apart. Still, no real need to go under the car, unless as Francis has indicated spray lube.
            Mike Zamora
            #12455
            • Joe R.
              • May 31, 2006
              • 1822
              Jerry,
              I replaced mine last year. I did not need to get underneath.
              Good luck!
              Joe
              • Jerry K.
                • 74
                Thanks all. Does anyone know the allen wrench size to remove the outboard? And oh yeah, where can I get correct belts with early '66 design logos.
                • Gary B.
                  • February 1, 1997
                  • 7078
                  '66 Seatbelt Removal; use an 8mm allen wrench!
                  Jerry,
                  If memory serves me correct the allen size is 5/16" (0.3125"). But here's a trick I found. The 5/16 felt a little sloppy when I tried it on the original fasteners on my '66, which were nearly seized in place. So I tried a 8mm (= .3150") allen wrench. I had to gently tap the 8mm allen wrench into the allen recess using a hammer, but it provided a much tighter fit and I was able to remove the original outboard bolts without stripping the heads.
                  Gary
                  • Jack P.
                    • March 19, 2009
                    • 1135
                    Re: '66 Seatbelt Removal; use an 8mm allen wrench!
                    Originally posted by Gary Beaupre (28818)
                    Jerry,
                    Gary
                    Same here. With the 8mm. But use a lot of kroil first and I had to use some heat. Go very easy, on bolt. Nut can be tough also.
                    Jack
                    • Frank E.
                      • May 31, 1986
                      • 189
                      Jerry,
                      Gary
                      They're not allen, they're torx. I believe size 15 but memory may not be spot on. If you use an allen wrench, you may just have a real long day ahead of you
                      Cheers....
                      Frank
                      Frank
                      1966 Milano Maroon Roadster
                      2004 CE Z06
                      • Gary B.
                        • February 1, 1997
                        • 7078
                        '66 seatbelt bolt type
                        Frank,
                        We have to be talking about different bolts, because the seatbelt bolts I'm talking about are absolutely, positively, Allen, not Torx.
                        Gary
                        • Frank E.
                          • May 31, 1986
                          • 189
                          Re: '66 seatbelt bolt type
                          Frank,
                          Gary
                          Gary...
                          I guess you're right on this. I just checked it and the allen and a torx 50 fit it fine. Don't know why I was of the impression that they were a torx but I'm not anymore. You can certainly put more on the allen wrench than a torx so I guess it's better to use the allen. Sorry for the confusion.....
                          Frank
                          Frank
                          2004 CE Z06
                          • Tom H.
                            • December 1, 1993
                            • 3440
                            These are the bolts from a 63.
                            Tom Hendricks
