I understand that a new judging guide for '66 is in revision & not yet available. My previous edition is loaned out, but apparently it indicates that both of the 327 engines used the xxxx369 cast iron housing. I believe this is in error, and that 300HP (as well as big blocks) employed xxxx660 die cast aluminum, with only L79 using '369' cast iron part in '66. Looking for confirmation of this ...
Jeff
Jeff
