"Hi Hat" Screw? - NCRS Discussion Boards
"Hi Hat" Screw?
  • Mike R.
    • August 30, 2009
    • 321
    "Hi Hat" Screw?
    The front of the S tube on a 1965 FI aircleaner assembly is supposed to attach to the radiator support with 4 Hi-Hat screws. What does a Hi Hat screw head look like? Does anyone have a photo of one either installed or by itself? Thanks
    Mike
  • Rich P.
    • January 12, 2009
    • 1361
    Re: "Hi Hat" Screw?
    Mike,
    here you go. 1/4" hex head High Hat screw.
    Rich
      Re: "Hi Hat" Screw?
      Good pix! I've seen different tip styles on used originals as well as different head marks (double anchor, 'A', plain). So, there were multiple suppliers for this fastener...
      • Gary J.
        • April 1, 1980
        • 1246
        Re: "Hi Hat" Screw?
        I'm not sure of all the applications that this screw was for, but do know that I found some on the last '66 that I restored. I also notice that in the '66 AIM that these screws are used on the AC ducting system.
        • Mike R.
          • August 30, 2009
          • 321
          Re: "Hi Hat" Screw?
          Thanks, I have seen these before. In addition to the S tube, where are they used? What is a good online source of midyear corvette hardware that has good quality photos on their site or in thier catalog?
          This is my first time on this forum and I am amazed at the quick responses
          I just purchased a 65 FI roadster and am making everything work correctly (parking brake, windshild washers etc), stoping some minor oil seeps and replacing/refinishing worn and ugly parts (seat belt cables, seat belt latches, a few hose clamps, screws ect.).
          Thanks again!
          Mike
          • Rich P.
            • January 12, 2009
            • 1361
            Re: "Hi Hat" Screw?
            Mike,
            you won't get a correct repro of this bolt. If you look on your heater control cables to heater box. you might find some there or sometimes used as a ground wire bolt. I have many different ones of theis example. You could go junkyarding and look under the dash of a 60-67 GM car your sure to find some. They also pop up on e-bay every once in awhile. I have't listed a set in a few months.
            Rich
              Re: "Hi Hat" Screw?
              I think some make the mistake of using the PN listed in the AIM to 'define' the high hat screw and then look for other situations where that PN is called-out. That method doesn't work!
              Many of the fastener PN's are simply generic with a plurality of suppliers qualified under that PN with slightly different variation(s) of the basic part. In this case, there was a price/cost penalty associated with the 'high hat' version of the screw. Deciding where/when to use it vs. a lower cost standard profile fastener was most likely a plant by plant and specific application decision.
              The attraction of the high hat screw was it tended to stay 'chucked' in a screw gun and not fall out as easily as its standard head profile brothers when the installer had to articulate to reach the installation position. But, there was a price to be paid for this convenience factor!
              Walking the scrap yards, these screws DO show up on other GM/Chevy cars but not very frequently. Knowing where/when to look is the trick to harvesting factory correct originals!
                Re: "Hi Hat" Screw?
                "They also pop up on e-bay every once in awhile. I have't listed a set in a few months."
                I have and the market has been so 'soft' in the last 6-months that it hasn't been worth the listing fee to offer them...
                • Mike R.
                  • August 30, 2009
                  • 321
                  Re: "Hi Hat" Screw?
                  Originally posted by Rich Pasqualone (49858)
                  Mike,
                  Rich
                  I guess I will add junkyarding to my list of activities.
                  • Bob J.
                    • December 1, 1977
                    • 720
                    Re: "Hi Hat" Screw?
                    Check out mid to late 60s GM pick up trucks when you go. Bob
                    • William C.
                      • May 31, 1975
                      • 6037
                      Re: "Hi Hat" Screw?
                      might want to look for something like the attached picture.
                      Bill Clupper #618
                      • Keith B.
                        • March 7, 2008
                        • 928
                        Re: "Hi Hat" Screw?
                        • Michael H.
                          • January 29, 2008
                          • 7477
                          Re: "Hi Hat" Screw?
                          Originally posted by Keith Brodbeck (14640)
                          I see the screw they list has a 5/16" hex head. I thought originals had a 1/4" hex??
                          • Rich P.
                            • January 12, 2009
                            • 1361
                            Re: "Hi Hat" Screw?
                            Mike,
                            I saw that too but from the picture it appears that they misslabled it and it is 1/4" hex.
                            Rich
                            • Keith B.
                              • March 7, 2008
                              • 928
                              Re: "Hi Hat" Screw?
                              Originally posted by Michael Hanson (4067)
                              I see the screw that list has a 5/16" hex head. I thought originals had a 1/4" hex??
                              ok that may be the wrong one. but I know they sell them. I bought them to use to restore my 66 Chevelle. I bought some kits they sell and they had them in there. you might want to call them. I bought this G-5687. and they sent me the screw you are looking for
