Front Brake Line Replacement - NCRS Discussion Boards
  • Roger D.
    • May 4, 2008
    • 301
    I'm performing a brake overhaul on a '72 350/200 auto coupe.
    Can the brake line from the proportioning valve to the right caliper be replaced without removing anything major?
    Thanks in advance.
    Roger
    • 6948
    Re: Front Brake Line Replacement
    Roger, I replaced the line in my 72 sm blk ,auto. it take a little patience , you'll need to make a few adjustments to the pre bent line to get around the fan shroud and to pass side caliper. start the job from the underside - center of front cross member.
    • Kenny C.
      • March 2, 2009
      • 191
      Roger
      If you are talking about the front lines it should be no big deal. As you can see in the photo it only has a few clamps tha hold it in place and even with the car in one piece you can access it from the underside.
      • Roger D.
        • May 4, 2008
        • 301
        Thanks guys, now that I know someone else has done it then I'll give it a try too! Got the parts on order now.
