Can this be done? - NCRS Discussion Boards
Can this be done?
  • Roger D.
    • May 4, 2008
    • 301
    Can this be done?
    Maybe I'm crazy for asking but.....
    On a '72 350/200 Auto coupe, can the brake lines going from the proportioning valve to the rear calipers along the chassis be replaced with the body still on the car and still be NCRS correct?
    Has anyone ever successfully done this?
    Thanks in advance.
    Roger
    • November 30, 1989
    • 11611
    Re: Can this be done?
    Yes and yes.
    Be thankful it's not a 4-speed.
    I've done an auto before and am about to do a 4 speed. At least with an auto you can partially remove the trans crossmember and it's a piece of cake. With a 4 speed, not so much.
    Patrick
    • Phil D.
      • January 16, 2008
      • 206
      Patrick a follow-up question. I assume you did it using a pre-bent unit out of one of the Corvette catalogs and not a "from scratch" coil of tubing. And I think I read somewhere that even the pre-bent units are shipped somewhat coiled up, is that right?
      Phil
      • Kenny C.
        • March 1, 2009
        • 191
        Not coiled but bent in half.
          • 15575
          A minor technical (after all this IS a tech board) point: Your Corvette does NOT have a proportioning valve -- unless you or some other person added it.
          Your Corvette does have a differential pressure/distribution block mounted on the frame just in front of the steering box.
          • Roger D.
            • May 4, 2008
            • 301
            Thanks for the replies. I guess the real hitch in the plan will be if I break off one of the brake line mounting bolts...after all I have no reservation in saying that they have been in there since original manufacture. There is surface corrosion and rust and drilling out a broken bolt would be near impossible...hmmm.
            Terry, I looked on Bair's and Zip Corvette websites and they call it a proportioning valve. On Corvette Central, they called the same part a distribution block. I looked in the AIM manual and they give it GM P/N 3980797 and call it a Switch ASM. I'm good with calling it a distribution block too.
              • November 30, 1989
              • 11611
              Phil
              Yes, the sort-of-prebent units from the Corvette catalogs.
              Far easier to install than a fuel line, though.
              Patrick
                • 15575
                I suppose differential pressure switch is the proper name, but it also serves as a distribution block. It is often incorrectly called a proportioning valve (in common conversation and on this site), but I would expect Bair's and Zip to know better.
                • Kurt G.
                  • April 30, 2005
                  • 343
                  Been there, done it, got the t-shirt. When you do it, replace the clips also. I agree with everyone else, pre-bent is the way to go.
                  Kurt Geis
                  Chairman, Midway USA Chapter
                  Targa Blue 1972, Top Flight and Duntov Award, 2014
                  Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
                  Arctic White 2013 60th Anniv Special Edition Conv.
