I need help. Just finished with a complete chasis restoration on an 67 L36. During its first test drive, I had after fire (popping) lilke no tomorrow. I went over the timng and the carb two or three hundred times already. I have it to were I can drive the car. But every once an a while I get a pop out of the exhaust (one side). The car seems to be surging. The plugs read good, there new ac delcos, (tan). Timing is set at 10* intial. It happens at about 40mph at approx 1500- 2000 rpm. very light throttle. Car idles perfectly 600rpms it will free rev with no problem.I have removed the points previously and installed one of the electronic conversion kits years ago on it. Never touched it since then. I have added the coil capicitor (+ side) for the radio this time around. Could this be giving me the problem. The reason I ask that is based on what I have read. Capicitors did not come on TI cars. This is a points car, not a TI car. However, with the elctronic Igniton, I'm wondering if this is some how effecting my coil. Which in turn is effecting my secondary ignition.
What I Have: Same new holley carb used for two years
same distributor -untouched
same engine untouched during the process.
