Brake Fluid for 1961 - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1299
    What type of brake fluid should I use when doing this brake overhaul?
    Jerry
  • Brian M.
    • February 1, 1997
    • 1840
    Re: Brake Fluid for 1961
    I would use Castrol DOT 4. JMHO
    • Cathy S.
      • August 31, 2003
      • 293
      Agree Dot 4
      • Jim L.
        • September 30, 1979
        • 1816
        This one will turn out to be more of a religious issue than a technical one. You wait and see....
        That said, I use silicone fluid (DOT 5) in all our old cars, even in my vintage racer. NEVER a problem. If you decide to use this fluid also, just know that pouring it in and bleeding of the system must be done at GLACIAL speeds to avoid entrapping air.
        Jim
        • John N.
          • February 1, 1975
          • 451
          I have both in cars and you will have less problems with DOT5 (silicone). I am tired of spending time rebuilding wheel cylinders etc due to the corrosion etc from the DOT 3&4 fluids. If I had a car that I drove 5,000 plus miles per year and prepared to replace the brake fluid on a regular basis I would maybe stay with the old fluids.
          Regards
          • John F.
            • March 23, 2008
            • 2414
            I agree with Jim & John. Rebuilt all of mine and flushed the lines with denatured alcohol. Everything works fine.
            John
            • Paul H.
              • September 30, 2000
              • 686
              Jerry
              If you are doing a complete overhaul, it's an excellent opportunity to convert to Dot 5. It doesn't collect moisture like Dot 3 or 4 and is perfect for cars that spend alot of time sitting. Just make sure you have purged all of the old brake fluid.
