61 2x4 WCFB Jets - NCRS Discussion Boards
61 2x4 WCFB Jets
  • David S.
    • February 22, 2009
    • 46
    61 2x4 WCFB Jets
    Rebuilding 2x4 270HP WCFB carbs. I have tanked and cleaned one so far, rebuilding now. Anyway the book has a note saying the primary rod jets has different openings than the secondary main jets. No kidding, but manual does not say which one has the smaller and larger opening. Anyone know which one is the secondary jet so I do not mix them up. I could pull apart the second carb, but have no clue if that one is correct either. Thanks for your assistance.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: 61 2x4 WCFB Jets
    David,
    Check this out......page 76(pdf pg37) has the answer. The large ones are the primary side. I thought they were as the stepped metering rods go through them.
    Rich
    • David S.
      • February 22, 2009
      • 46
      Thanks Richard, perfect. Exactly what I was looking for.
