55 v8 powerglide numbers - NCRS Discussion Boards
  • John S.
    • July 29, 2009
    • 640
    what would be the correct powerglide numbers for the 1955 V8? i'm looking for the converter housing casing numbers, main case and tail piece numbers. going a little past the tailpiece knowing the correct differential carrier case numbers would also be helpful! the judging guide is not much help with the V8.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 55 v8 powerglide numbers
    Cant get under my 55 now but would be the same as car , check with Chevy guys their better on numbers then NCRS . The torque Converter is different then a car ,it's Corvette only
    • Fenwick B.
      • January 1, 2005
      • 115
      The transmission case number should be 3708134, and the torque converter number should be 3708188. I'm not sure about the tail shaft number.
