Finish of metal brace on rear bulkhead of '64 convertible - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    I have removed the rear suspension from my '64 convertible and have discovered, not only original grease pencil marks from the factory on the exterior of the rear bulkhead, but also a metal bracket that was riveted to the bulkhead, as well. This bracket is covered with surface rust and the original finish is un-recognizable....
    Does anyone know what the original finish of this bracket was....?
    thanks....
    Garry Eastwood
    #38705
  • Joe C.
    • August 31, 1999
    • 4598
    Re: Finish of metal brace on rear bulkhead of '64 convertible
    If the body was from AO Smith it should be zinc phosphate primer.
    If St. Louis it was gloss black.
    • M W.
      • July 31, 2001
      • 835
      Gary, if you look in the upper right corner of that same area you will see a ink stamp showing the date the body was assembled. Only visible if the tank is removed. I have a great picture somewhere I will try to post later.
      cheers,
      Craig
      • Michael G.
        • January 1, 1997
        • 1251
        Only info I've seen there is the job # written on bulk head with a lumber crayon....be it from A.O. Smith or St. Louis. A.O. Smith however did incorporate a letter with their job #. Would be interested to see a ink date stamp image.
        • Wayne M.
          • March 1, 1980
          • 6414
          Slightly off the direct 1964 question; at what point in the 1963 MY did this "Underbody Reinforcement" (per AIM nomenclature) begin ?
          I could never figure out exactly what was being 'reinforced' .
          Tidbit -- all tankers were, of necessity, U-R delete.
          • M W.
            • July 31, 2001
            • 835
            Here you go guys. If you look very closely at the middle picture you can the see the job number in crayon and the finish date i assume of MAR 25 1964 upside down in the upper corner as well. Neat stuff.
            Craig
            • Joe C.
              • August 31, 1999
              • 4598
              Craig
              Each individual body panel had it's own date of manufacture ink stamped into it.
              The body assembly date itself is only found on the trim tag.
              If the ink stamp on a particular panel happens to match the date on the TT, then it is purely coincidence.
              • Joe C.
                • August 31, 1999
                • 4598
                Are you saying that early/mid 1963 MY cars did not have the bulkhead reinforcement?
                I agree that the steel doesn't seem to be "reinforcing" anything.
                My best guess is that if it was added, then it might have been to address a noise isolation issue. The large, flat rear bulkhead might have been drumming, and so the "stiffener" was added.
                • M W.
                  • July 31, 2001
                  • 835
                  Joe I dont disagree with or agree cause I don't know the answer but this is the only panel I could find with an ink stamp on it.
                  Craig
                    Craig
                    Craig -
                    The ink-stamped date is the date the panel was molded at the panel supplier.
                    • Alan D.
                      • January 1, 2005
                      • 2046
                      Another number that turned up! Interesting stuff as you look at the details.
                      Have found a few ink stamps on panels and yes one in the back once tank was removed to look for Job Number.
                      • Garry E.
                        • 240
                        All....
                        Thanks for the various responses to my intial inquiry..... all very useful.... I have attached a couple of photos of some of the inspection marks I have discovered in this process..... Thanks again...
                        Garry Eastwood
                        #38705
                          Here's a St. Louis-bodied '67 undergoing restoration - the rear bulkhead stiffener was dip-primed black.
