70 sb plug wire lengths - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    Can someone post or email the individual wire length chart for 70 sb?
    Thanks, Bill
  • William C.
    • May 31, 1975
    • 6037
    Re: 70 sb plug wire lengths
    If you want to pull the part numbers off the AIM, I probably can give you the wire length.
    Bill Clupper #618
    • Jeffrey S.
      • May 31, 1988
      • 1899
      Bill:
      Here are the lengths as listed on the instruction sheet from a set of Lectric Limited wires: #1 = 48.0", #2 = 48.0", #3 = 48.0", #4 = 45.0", #5 = 32.0", #6 = 32.0", #7 = 27.5", #8 = 26.0". Hope this helps.
      Jeff
      • Bill L.
        • February 1, 2004
        • 1403
        Thanks Jeff!
        That is exactly what I was looking for.
        Bill
        • Bill L.
          • February 1, 2004
          • 1403
          Do you measure the length from end to end or from the inside of each boot to the inside of each boot?
          I am asking because I bought a set of Pertronix black wires and it looks like I will be cutting them all down.
          Thanks! Bill
