Vacuum Advance Part Number? - NCRS Discussion Boards
  • Christopher K.
    • September 10, 2007
    • 311
    I'm looking at an original '73 L82 4spd distributor, 1112150.
    The advance is a "524", shouldn't it be a "448"?
    Thanks for any help,
    Chris
    Chris
    '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
    '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Vacuum Advance Part Number?
    Chris:
    My application book shows the 448 as correct.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • William C.
      • May 31, 1975
      • 6037
      Delco Remy Service manual calls for 448
      Bill Clupper #618
      • Christopher K.
        • 311
        Thanks guys,
        Does anyone know what a "524" is for?
        Joe L?
        Chris
        Chris
          • 43281
          Originally posted by Christopher Krieger (47844)
          Thanks guys,
          Joe L?
          Chris
          Chris----
          I can find no record of any vacuum control the last 3 digits of which are '524'. It's possible that one once existed of GM #1973524. If so, though, it was a PRODUCTION-only piece. Are you sure the number is '524'?
          • William C.
            • May 31, 1975
            • 6037
            I'm with Joe, I looked at all the oem GM Vacuum cans in the 1963-77 timeframe and found no "524"
            Bill Clupper #618
            • Christopher K.
              • 311
              Thanks Joe and Bill (and Tom!),
              Seller rechecked numbers and says it's definitely 524.
              He pulled it from his original '73 L82 4spd, tag says 3 A 22.
              He said it looked like it "hasn't been messed with"
              Joe, is that 524 part number for a 15 degree vacuum advance, like the
              "448 15" ?
              Chris
              Chris
                • 43281
                "448 15" ?
                Chris
                Chris-----
                I don't have any information, at all, on the '524'. I don't even know if it actually existed, although the situation here is pretty good proof that it did exist. I just theorized that it MIGHT have existed since GM #1973523 and GM #1973525 were once distributor vacuum controls that did exist. So, it's very possible that there was once one "in between". However, if there was, it was never available as a SERVICE part and I have absolutely no information on it.
                As I mentioned, it is possible that it was a PRODUCTION-only piece that was used alternatively with the GM #1973448. In fact, if the distributor is of GM #1112150 and appears to be "un-messed with" and given that it's, apparently, a 15 degree vacuum control, then I strongly suspect this is what it is. I have no information to support that, though. It's just a hunch based upon what I have found. IF my hunch is correct, I would expect this control to have the same or virtually the same specs as the 1973448.
                • Christopher K.
                  • 311
                  Thanks Joe, that's great info. If I end up getting it, I'll post a picture.
                  Chris
                  Chris
                  • Christopher K.
                    • 311
                    Well, the plot thickens. You just never know what's next...
                    Seller told me the only other numbers on the vac advance were CCW - So he was talking about the CAM and WEIGHT PLATE! (which looks correct to me)
                    I had him look at the "cone shaped vac advance" and he says it reads
                    437 15
                    In my parts book that is part #1973437 for a '71-'72 350 w/1112038-50.
                    That's a for an Lt-1 engine, I believe.
                    Any thoughts on this vac can. Could it have been put on a '73 L82 in production?
                    Chris
                    Chris
                    • William C.
                      • May 31, 1975
                      • 6037
                      The vacuum advance was part of the emissions certification in 1973. The chances of an incorrect one leaving the plant, somewhere near zero.
                      Bill Clupper #618
                      • Christopher K.
                        • 311
                        Thanks Bill,
                        Anyone can put a tag on a distributor, I think I'll wait for one with ALL the correct numbers.
                        Chris
                        Chris
                        • Wayne M.
                          • March 1, 1980
                          • 6414
                          .... Seller told me the only other numbers on the vac advance were CCW - So he was talking about the CAM and WEIGHT PLATE! (which looks correct to me)
                          437 15
                          That's a for an Lt-1 engine, I believe...
                          Chris -- while you're waiting for "all" the numbers, your analysis seems correct to me (ie. the 437 can on the 2038 / 2050).
                          For example, I have a 1971 LT1 "2038"_0-J-3 date, also with the 437_15 can (no MS on the first line). So seller is reading the rotating weight plate, with "524_CCW" stamped (on top or bottom ? I've seen both locations). My "2038" weight plate is stamped "534" (no CCW) on top. Ask him to see if there's a stamped number on the shaft's autocam (ie. football). My "2038" is stamped '170W' on the underside (or sometimes the cams are stamped with 2 or 3 digits on top, or sometimes underlined).
                          So there's quite a few numbers to totally define a distrib. Would be nice if someone with a '73 "2150" could chime in with their numbers.
                          • Christopher K.
                            • 311
                            Thanks Wayne,
                            Great info
                            Chris
                            Chris
