Should an original '73 PF-25 have an embossed bottom? "AC" within a circle in the middle and "ALWAYS REPLACE WITH" around the edge.
Question on PF-25 oil filter
Bloomington Gold 2011
Corvette Magazine 9/11
Bloomington Gold 2013
Corvette Magazine 3/13
50th Anniv Display Corvettes @ Carlisle 2013Tags: None- Top
Re: Question on PF-25 oil filter
Probably not. The emboss on the bottom may have gone into the beginning of 1972, or might have ended during 1971 -- IMO.
Give your post some time for others to chime in. Some of these oil filter details, somewhat like air filter details, are subject to a lot of opinions.Terry- Top
William I agree with Terry some where at the end of 71 or early 72 the embossed filter was replaced by the white body none painted upper flange not embossed. The wording you have ALWAYS REPLACE WITH sounds like a Canadian version of the PF-25 the originals had BEST WAY TO PROTECT YOUR ENGINE REPLACE WITH. Paul 18046- Top
Terry's very correct......there are many differing opinions on these filters. Some feel the circular embossed never left the assembly line, they were only service replacements. The months and years of usage are also in some dispute.
In my former life, I sold NOS parts and studied NOS oil filters for about 25 years. One thing my own research found, no one that I am aware of, has ever produced definative proof as to the exact usage, or lack of, for this circular embossed oil filter. Even a certain well known, extremly low mileage C3 (under 1,000 miles), I have been told by a reliable souce had received a break-in oil change. So that assembly line filter, like possibly, all the others is gone from history. Not too many people saved old, original oil filters for historical research.
I'm sure that those with better knowledge than myself will come forward with some good advice for you. Ridge.
Good carburetion is fuelish hot air . . .- Top
William I agree with Terry some where at the end of 71 or early 72 the embossed filter was replaced by the white body none painted upper flange not embossed. The wording you have ALWAYS REPLACE WITH sounds like a Canadian version of the PF-25 the originals had BEST WAY TO PROTECT YOUR ENGINE REPLACE WITH. Paul 18046Lyle
- Top
William I agree with Terry some where at the end of 71 or early 72 the embossed filter was replaced by the white body none painted upper flange not embossed. The wording you have ALWAYS REPLACE WITH sounds like a Canadian version of the PF-25 the originals had BEST WAY TO PROTECT YOUR ENGINE REPLACE WITH. Paul 180461973 LS4 coupe. Dark Blue / Black. Turbo Hydra-Matic, PW, PB, PS, Rear Defog, Tilt/Tele, AC, Map Lamp, AM/FM.
50th Anniv Display Corvettes @ Carlisle 2013- Top
Bit the bullet and bought one of the good ones. Thanks.1973 LS4 coupe. Dark Blue / Black. Turbo Hydra-Matic, PW, PB, PS, Rear Defog, Tilt/Tele, AC, Map Lamp, AM/FM.
