Fuel gauge problems on C1 - NCRS Discussion Boards
  • Valeria H.
    • July 27, 2009
    • 463
    I had all of my gauges restored thru Ecklers this past year. My mechanic has been having problems with the fuel gauge working intermittently. He still thinks the gauge is malfunctioning. I know I have the option of sending the gauge back to Ecklers but does anyone have a name for a second opinion?
    I really want to get my car back "on the road, again!" Singing music with friends!!!
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Howard M.
    • June 30, 2000
    • 124
    Re: Fuel gauge problems on C1
    Check the archives for fuel gauge info. Be sure the sender is properly grounded by running an additional ground wire from one of the sender mounting screws to a convenient point on the frame. Many fuel gauge problems are due to a bad ground.
    • Stewart A.
      • April 16, 2008
      • 1035
      C1's are a menace for reading incorrectly. Howard is correct bad ground is normally the problem. Run a separate wire. I have run out of gas like a looser that I am 3 times now. It's getting to the stage where I will keep a can i the trunk. I haven't had time to run a separate ground wire. Stewy
      • Valeria H.
        • July 27, 2009
        • 463
        Oh God, That is not very incouraging Stewy! I have printed these pages to give to Ricky Zarbonickic (it really is a great name!!!) my trusted and knowlegable mechanic, to view. Thanks for the info,
        Valeria
        Valeria Hutchinson
        • Louis T.
          • July 31, 2003
          • 282
          Hi Valeria,
          Below is an excellent article on C1 fuel gauge diagnosis written by John Hinckley that you and your mechanic might helpful:
          http://www.lbfun.com/warehouse/tech_...lGaugeTech.pdf
          Good luck!
          Louis
          • Valeria H.
            • July 27, 2009
            • 463
            Thanks Louis!!! Excellent article. I've been having a problem with the back brake lights coming on by themselves and depleting the battery too. I feel certain this will solve the problem. A new switch was applied to the brake lights and the problem on that issue seems fixed for now on that front. I'll fax this to my mechanic now.
            Thanks to all for all your suggestions and assistance,
            Valeria
            Valeria Hutchinson
