69 replacement battery question - NCRS Discussion Boards
+ More Options
Posts
  • Joseph H.
    • December 11, 2007
    • 159
    I have read plenty in the archives regarding replacement/restoration batteries. I want to replace the battery in my 69' with a battery that fits into the holder correctly. Does GM make a sealed battery that fits correctly? Anyone with a part number? I am tired of the battery sliding around.
    Thanks for the help.
    Joe
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 69 replacement battery question
    Joesph I do not believe you can get a sealed, no way to add water, battery for your 69 that says AC Delco.
    I just bought a 75 AC Delco Professional for my 1985. It has 700 CCA and a 7 year warranty and a 50 month free replacement. It installed just fine and is secure with the use of original retainers to hold it in place. The AC Delco I replaced was in the car for about 9 years.
    • Joseph H.
      • December 11, 2007
      • 159
      So, are you saying that the battery for the 75' is different than the 69' ? Is the battery you purchased labelled AC Delco?
      I am still a little confused.
        • 43282
        I just bought a 75 AC Delco Professional. It has a 7 year warranty and a 50 month free replacement. It installed just fine and is secure with the use of original retainers to hold it in place. The AC Delco I replaced was in the car for about 9 years.
        Jim----
        I assume you mean that you used a 75 series battery. If I'm assuming correct, why did you use this series? The 75 series is a smaller size battery used for C4 Corvettes. L1969-82 Corvettes use a 78 series (or, 78 DT) battery which is somewhat larger than a 75 series and, usually, of higher capacity.
        • Joseph H.
          • December 11, 2007
          • 159
          Joe,
          OK, I guess I should just call the Chevrolet dealer and ask about a 78 series battery. I am not interested in a restoration battery, just something that fits correctly.
          Joe
            • 43282
            Joseph----
            1969 Corvettes used two different batteries. Early 1969 (to about S/N 22,000, as I recall), used a top post style battery. Later 1969's used a side terminal battery.
            For current replacement, you can use either a group 24 or 78 DT (dual terminal battery) for the early 1969 configuration. For later 1969, you can use either a group 78 or 78 DT battery. If you want the configuration to be as correct as possible, use only the group 24 for early 1969 and only the group 78 for later 1969.
            Delco-branded batteries are available in all three of the above-referenced group sizes. I believe they are available in -5YR, -6YR, and -7YR suffixes. I recommend only the -7YR (i.e. 7 year battery). The -7YR, if not all the variants, are no longer a "sealed" battery. They are what's referred to as a "low maintenance" battery. So, they have caps which can be removed, but are "recessed" to make them more difficult to remove.
            Actually, batteries once labeled as "no maintenance" were never a COMPLETELY sealed battery. That type had no caps, but they did have vents.
              • 43282
              Joe,
              Joe
              Joe-----
              As I mentioned in my most recent post, it depends whether you have a 1969 with top post or side post type battery. If you don't care about "most correct" configuration, a 78 DT (dual terminal) will work fine for either (the top posts, unused for late 1969's, still make a great place to charge or jump start the car if you need to; much easier than the difficult-to-access, FORWARD-mounted 1969-only side terminals).
              For early 1969 top terminals you can also use a group 24.
              A Delco dealer might be the best place to get a battery.
              Any of these batteries will mount correctly and securely for your application (provided you install the battery retainer correctly and as-designed; if you install it UPSIDE-DOWN, the battery WON'T be mounted securely and correctly).).
              • Joseph H.
                • December 11, 2007
                • 159
                Thanks, I missed your earlier reply that referenced the details. I do have a very early 69', but someone has long changed the cables to the side mount cables.
                I will check with my local dealer and decide if I want to replace the cables to top mount cables. I will also check my judging guide to assess the $$ to point value.
                I do have the clamp to hold down the battery, but the current battery is way to small no matter how I position the hold down.
                Thanks again,
                Joe
                • Jim T.
                  • March 1, 1993
                  • 5351
                  Jim----
                  Joe I bought the battery for my 85 and have changed my post.
                    • 43282
                    Thanks again,
                    Joe
                    Joe-----
                    Purchasing new cables, either current GM replacements or original-style reproductions will not be too expensive. However, installing the the positive cable can be a PIA. It requires removal of the transmission tunnel insulator and that, in turn, requires removal of the transmission. So, the job can get pretty involved. It's no problem if you have the transmission out for other reasons, though.
                    What series battery is in the car now? The battery groups are pretty standard, so no matter what brand is in the car, it should have a group size on it somewhere.
                    The original 1969 side terminal battery had the terminals oriented towards the FRONT of the car. What orientation is your battery with the existing side terminals?. If it's towards the REAR of the car, then the cables were replaced with later style configuration.
                    • Lawrence M.
                      • February 1, 1995
                      • 404
                      Joseph----
                      Joe, the Ac Delco book recomends the 6yr 78 for my late 1969. I like the idea of the extra top posts of the 78DT for my float charger or jump statring. I also would rather have the 7yr battery. Do you know if the 7yr is much bigger, if any than the 6yr? I imagine the only dimension that might cause trouble would the height. Looks like about 9 inches from the bottom of the battery box to the underside of the door. Hope to get the battery tomorrow. Thanks for any more info you can help with.
                      Larry
                      Larry
                      2002 Z51 Convertible
                      1969 L46 Convertible
                        • 43282
                        Larry
                        Larry----
                        The 7 year battery is the same size as the others.
                        • Lawrence M.
                          • February 1, 1995
                          • 404
                          Larry----
                          Thanks Joe, I'm off to the my local Delco dealer for a 7yr 78DT in the morning.
                          Larry
                          Larry
                          • Joseph H.
                            • December 11, 2007
                            • 159
                            Joe,
                            My battery has the terminals oriented toward the front of the car, but they are side terminal cables. I think they have been replaced and are wrong because I have a very early car, serial 1291.
                            Thanks for all the info, I will take a look when I can to see how big a job it is to change the cables and go from there.
                            Thanks again,
                            Joe
                              • 15634
                              Joe,
                              Unless the body is off the frame, or the transmission is out of the car, changing the positive battery cable on a C3 IS the biggest PITA there is. Well maybe not worse than the power brake booster, but close. Even interior work is easier than changing that cable. The negative cable will be easy, though.
                              It is a long shot, but I was told that some (like perhaps a few hundred) 1969s were built with copper clad aluminum cables. There will be stamped lettering on the cables to that effect. Check for that before you conclude the cables have been replaced. I would expect if the cables have been replaced the install might look more amateurish than if it was done at St. Louis.
                              The engineer who told me about this test group didn't tell me if they were side-terminal or top-terminal -- and of course I didn't think to ask. We were discussing side-terminal batteries and cables at the time.
