Rusted screws - NCRS Discussion Boards
Rusted screws
  • Valeria H.
    • July 27, 2009
    • 463
    Rusted screws
    I purchased a set of four wheel covers and spinners for a 1960. I have been able to remove the spinners on all of the wheel covers except 1 of them. I have used kroil saturation for the last several weeks without results. I purchased several other loose spinners that I can have rechromed but I need to get the spinner off of the wheel cover. Can anyone give me thoughts at how to go about this? The screws are really rusted into the wheelcover.
    I don't care about the spinner but I need the wheel cover free. I have a dremmel. Could I dremmel off the screw?
    Valeria
    Valeria Hutchinson
    Past Chairman of the Carolinas Chapter
    1960 Roman Red w/ White Coves -"Bella"
    2005 Millennium Yellow 6 speed 400 HP - "Trixie"
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: Rusted screws
    Use a grinding disc on the dremel and grind off the screw head. Be careful not to damage the wheel cover.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17655
      Re: Rusted screws
      First buy some CRC Freeze Off in a spray can from O'Reilly or other parts store. Spray screw head every five minutes six times - thirty minutes and try to remove it with a screw driver. If that fails carefully cut off the head with your Dremmel. Good luck, Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Valeria H.
        • July 27, 2009
        • 463
        Re: Rusted screws
        Thanks, I am at a despardo point with this wheel cover.
        Valeria
        Valeria Hutchinson
        • Joe M.
          • April 30, 1990
          • 1338
          Re: Rusted screws
          I have had occasional luck using a new pair of vice grip pliers and clamping onto the tip of the screw and twisting the screw out; you get better leverage that way. Best case, it comes out, worse case, it twists off.
