66 Steering Gear Box Cover - NCRS Discussion Boards
  • Dave B.
    • April 30, 1984
    • 248
    My '66 L79 with telescopic steering has a correct steering box case from Saginaw #5677649. The cover says CHECK--> <--Lube but does not have the needed part # 5666723. Appears I have a cast iron replacement top.
    Does any one know if these correct tops are available...or came on any other GM cars? Can't find any reference to them being interchangeable with any other cars.
    Dave
    • 43247
    Re: 66 Steering Gear Box Cover
    Dave
    Dave-----
    I don't know that every one of these covers actually had the casting number on it. In any event, these covers were used on MANY other Chevrolet applications, including:
    1955-68 passenger cars without power steering
    1960-68 series 10 thru series 30 trucks
    • Dave B.
      • April 30, 1984
      • 248
      Thanks Joe...as always.
      Just got the car judged at chapter and took a ding for not having a number. Will hit my favorite yard to see what I can find.
      Dave
        • 43247
        Dave
        Dave-----
        These covers were really never designed to be serviced. In other words, the bushing was pretty much designed to be replaced with the cover, if replacement was necessary. However, the bushing can be replaced, albeit it must be done carefully. A reduced length, lower bushing can be used for replacement.
        • Dave B.
          • April 30, 1984
          • 248
          Hmmmmm... May give this some thought. Might be a lot of work and trouble for a couple of points.
          Cheers,
          Dave
          • Gary R.
            • April 1, 1989
            • 1799
            Keep in mind replacing the cover will require proper lash setup. Doing this wrong will wreck the gears. I've replaced way too many gears sets that were worn out by improper box setup in the past by alignment shops, garages,and owners.
            • Dave B.
              • April 30, 1984
              • 248
              Gary,
              You and Joe convinced me to leave well enough alone.
              Cheers,
              Dave
              • Gary R.
                • April 1, 1989
                • 1799
                Sorry Dave, didn't want to stop you- just inform you. I am doing a box now for a NCRS car to install the correct cover as well. This box was "rebuilt" before I got it and was done poorly. The gears were welded. You can see what I found here maybe you'll find it interesting. The box is now going to be better then it ever was from day one.
                • Dave B.
                  • April 30, 1984
                  • 248
                  Thanks Gary,
                  Just redid the front end and my steering handles quite nicely. A previous owner must have had the steering box rebuilt which may explain the after-market cover.
                  It is obvious you do fine work, and I will remember that for the future.
                  Dave
