C-1 door drain holes - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2424
    Are there supposed to be any drain holes in the doors? If so, where are they located (front to back) and (side to side)? I was washing the car and after finished could hear a little water sloshing around in the door.
    John
  • Steve H.
    • November 1, 1996
    • 118
    Re: C-1 door drain holes
    On 56/57 they are two on the bottom of each door. They are thin slots in the lip that joins the outer skin and inner door on the outside of the door gasket. They tend to stop up with trash so a hack saw blade inserted in the slot and carefully worked around does well.
    Steve
    • John F.
      • March 23, 2008
      • 2424
      Thanks Steve. I found them. Four on each side.
      John
