How to adjust windows and doors. - NCRS Discussion Boards
  • Robert T.
    • May 31, 2000
    • 9
    1964 I have problems with the side window sticking when rolled all the way down. How do you adjust
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: How to adjust windows and doors.
    Is yours a coupe or convertible? Don't know if it makes much difference except I know the converts are inclined to sag which affects the window adjustments/fit at full up. The lower adjustments are not too difficult once you get the door panels and access panels off. Many years ago I did mine and in the process I sort of rehabed the roll up mechanisms by tightening up the pivot pins, cleaning and relubing the channels, etc. I used all new felt guide channels as well.
    Others will probably jump on with more specifics. If you rehab everything as I mentioned above, I'm sure you will eliminate your sticking condition.
    Stu Fox
