t 10 rebuild - NCRS Discussion Boards
t 10 rebuild
  • Jack A.
    • March 1, 2001
    • 129
    t 10 rebuild
    Hi Guys,
    I am rebuilding my 61 Borg Warner Alum T 10 transmssion. I would like to find some information on how to properly put it back together. It was a mess and I had to get almost all new parts. I know there is something somewhere that will walk me through it but I could not locate it in the "Forum",
    Jack Alexander 35730
  • William C.
    • May 31, 1975
    • 6037
    Re: t 10 rebuild
    Easy way is to use the ST-12 Corvette Servicing Guide or a 59 or newer Chevrolet Service manual. If you have ever done a Muncie, they are similar but with a couple of quirks regarding selective fitting of snap rings.
    Bill Clupper #618
    • Ridge K.
      • May 31, 2006
      • 1018
      Re: t 10 rebuild
      Jack, you didn't mention if you have ever done one before, but.....here's a website that might be of help:
      www.1bad6t.com/trans.html
      I am going over to fellow member Scott Pfuehler's shop tomorrow, to have Scott rebuild a 1962 T-10 for me. I am certainly not trying to tell you what to do, but I would always recommend to a friend who has never rebuilt a four speed, to consider using someone experienced to either do the work, or walk them thru it in person. Just a thought.
      Perhaps the website will steer you in the right direction. best of luck in the adventure. Ridge.
      • Richard T.
        • February 1, 1979
        • 858
        Re: t 10 rebuild
        Just finished rebuilding the T-10 from my 62. I had to replace almost everything including main shaft but it now works like new. I found a good source for parts "D &L Transmissions" from Long Island N.Y. They have a great selection of new and used parts for T-10 and Muncie transmissions. Darrel is the owner and his wife fields the calls during the day as he works. They ship UPS every night. I changed the sliders on my NOS synchros to their "torque lock" which are designed to help prevent the transmission from sliding out of gear. Check their web site. Rich
        • Jerry W.
          • January 27, 2009
          • 588
          Re: t 10 rebuild
          I recently took my 62 T10 to a local rebuilder for a syncro refresh as it was popping out of second gear. Flat fee of $225 labor plus parts. It turned out ugly...syncros...rebuild kit...2nd and 3rd gears and main shaft..( spline on the main shaft was twisted ) Don't be suprised what you find in there....total cost $1311.......Good luck.
          • Jack A.
            • March 1, 2001
            • 129
            Re: t 10 rebuild
            Hi Guys,
            Well as usual the information was perfect. The website was spot on. I can get my hands on the Manual. I already got the parts fron the source suggested per a previous question to the Board. Thanks for the info and most of all thank you for taking your valuable time to help me.
            My project is about a month from completion and I can't wait. I could not have done this without you.
