holley vacuum leak - NCRS Discussion Boards
holley vacuum leak
  • William F.
    • June 9, 2009
    • 1363
    holley vacuum leak
    My '67 300hp with Holley carb has developed a vacuum leak. It really squeals! I've checked all vacuum hoses/ports and that's not the problem. Carb is tight to manifold-I haven't taken carb off manifold to check anything .Where is leak-air horn to throttle body; I hope not?
    William Ford
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: holley vacuum leak
    William Ford
    make sure the carb to intake gasket shape matches the intake manifold opening shape,the holes in the gasket a perfect match to the holes in the intake. check the main body and throttle base plate for flatness as they may need machined
    • David S.
      • August 9, 2009
      • 595
      A friend of mine had a similar experience, ended up being the gasket between the intake and carb. For cheap insurance, replace that gasket and see if anything changes.
      -Dave
      • Clem Z.
        • January 1, 2006
        • 9427
        -Dave
        like i posted above make sure the openings in the gasket are a match for the openings in the intake manifold. do not use a full open gasket on a manifold that has 2 round and 1 oval opening. if the manifold has 4 round openings you need a gasket to match
        • Tim S.
          • May 31, 1990
          • 704
          Has your car had any service lately or did the wistle come out of the clear blue? You may have lost a carb gasket. Carefully inspect the baseplate of the carb for cracks. The throttle shafts may be suspect. I had one with that. If you were to use a propane cylinder with a hose, you can pinpoint the leak location without making a mess.
          Best of Luck!
          Tim
          • William F.
            • June 9, 2009
            • 1363
            No recent service , whistle just came out of blue. If I replace the carb to manifold gasket, do I have to use a new stainless steel spacer that is used on the '67 300 hp engine or can I use the old spacer with a new gasket?How do I pinpoint a vacuum leak with a propane tank and hose(what kind of hose?)?
            William Ford
            • Tim S.
              • May 31, 1990
              • 704
              You can use the old stainless shim. As far as the hose, anything will do to put on the end of the propane tank. The hose allows you to control where the propane goes to help pinpoint where your are diagnosing. Like carb cleaner, the RPM will pick up.
              Tim
              • Clem Z.
                • January 1, 2006
                • 9427
                William Ford
                i would try installing a gasket between the carb and the stainless plate as that stainless plate requires a very flat throttle base plate to seal. this worked good on all new flat parts but as parts loose the flatness the seal there is suspect
                • William F.
                  • June 9, 2009
                  • 1363
                  Could overtightening the wing nut to stud that holds air cleaner top have warped the carb and caused vacuum leak?. I haven't had this car long and have noticed that it's hard to"catch a thread" on stud with wing nut-stud too short or part of air cleaner assembly too tall.
                  William Ford
                  • Jeff C.
                    • September 30, 1997
                    • 233
                    Bad power valve. My Brother-n-law had same problem with his 66 350 HP.
                    Jeff
