Hello folks,
Two questions--let me pick your brains
1.) Is the air cleaner base assembly different on a 1970 Lt-1 vs. the open element air cleaner base on a 1970E 350? The reason being when my 350E base is installed on the Lt-1 carb/manifold set-up, the crankcase vent tube can't reach it's fitting in the right hand valve cover. Do I need a new Lt-1 specific air cleaner base.....or a different elbow and hose? The catalogs seem to suggest there is a specific Lt-1 air cleaner base.....why, is the tube on the bottom of the base longer?
2.) When attempting to re-connect the fuel line from the "y"-block to the fuel pump, the fuel line (the correct Lt-1 line) appears to be too short to reach the location of the 90 degree fitting on the fuel pump. Bear in mind this is the 350 fuel pump, not an Lt-1 fuel pump. Is the 90 degree fitting on the Lt-1 fuel pump in a different position than the 90 degree fitting on the standard 350 fuel pump? If my 90 degree fitting could be rotated about three inches, it would connect up. The standard 350 fuel pump also has three inlet/outlet fittings on it, while the Lt-1 fuel pump appears to have only two fittings...what gives? If I need to swap in the Lt-1 fuel pump in order to connect it up, what happens to that third line?
As always, your help is certainly appreciated!!!! Best Regards, Jim
